Not responding in what sense? From code reader? Are you plugged in under bonnet? No read from dash connector - engine only.The module isn't responding so I guess that's had it too![]()
I'm using the 20 pin under the bonnet. When I select read air bag codes it just says no connection etc.Not responding in what sense? From code reader? Are you plugged in under bonnet? No read from dash connector - engine only.
Could also be just a bad contact, try using some electrical contact cleaner spray on the 20 pin socket.I'm using the 20 pin under the bonnet. When I select read air bag codes it just says no connection etc.
Of course there is the possibility that Captain special took a set of chops to it.
Try asking Andy @spurs fan in a coupe for a module, and maybe some seat looms if he has any.Will do.
Finding a new module and coding looks a real head ache.
You can just sneak your hand under if you remove the screws on the passenger side. And look through the gear-lever gaiter hole. But it’s not ideal and tends to bend out the wing of the console a little.What info is needed to find the correct one?
I'm assuming it's a center console out job just after I refitted it?
Not sure what you’re looking for/asking?I get the feeling it isn't SRS/airbag related but what
Out of interest where on original OEM are the airbag modules. For the life of me I can't find them.
Not under airbag like I would expect.
No problems, thanks for having a look.
My experience is these facelift modules can be a little hard to find. So ordering from abroad may be your best bet. Just check out their feedback carefully. I think many of these guys in Lithuania are genuine BMW specialists.I can find it if I search the part number from the module but not under any of the categories like electrical or airbag.
Found a module on eBay from Germany with the same part number or one from Lithuania. Is it worth the punt?
