Daspete
- Jan 13, 2019
Hi all,
Just found that the previous owner had an issue with the SRS / Airbag system and rather than find a solution they just took a set of pliers to it.
So I bet you're thinking, what about the dash light and the back up?
Mr bodgit had a solution to that too. Wire a bulb from the airbag light hole to the ABS light so it goes on and off like it should for an MOT then just taped over the back up.
I want to fix the system if I can and the issues seem to be with the driver's seat. They've cut everything.
The passenger seat has an occupancy sensor bypass on which is not a concern for the moment.
On a face lift 2001 Z3 what should be there?
The only thing left is the cable to the pretensioner. I've found the remains of a wire from the buckle but have no Idea where it goes.
Any help would be greatly appreciated or does anyone have a complete seat/seats from a late model in black in good condition I could buy?
Thanks in advance
Thanks in advance
