Winter tyre storage
Tim Palmer
North Yorkshire
Z3 2.2i
Looking at a couple of options for winter storage tyre storage.
on line recommendation increasing tyre pressure to 3.5bar but only for 3 months.
can you keep at this pressure longer.
or- buy tyre trainers that cup the tyre on the ground. Some have wheels to move the vehicle around.
any thoughts on winter tyre storage. Thanks
Winter tree storage??
You need to edit your thread title Tim. ;)
I don't store mine as I drive it all year so can't help with your question.
B21
Scottish Borders
E89 35is
The max permitted pressure is shown on the sidewall..inflate it to that..if its going to run in the summer that's all you need..if you're going to sorn it for the next 10 years maybe a different solution..
Pond
Spaldingski, Lincs
Z3 project
I learned quite a bit about tyres from a post on another forum, where someone had a problem and went to Michelin for advice. Michelin sent a very, very detailed answer which was extremely informative. The following is paraphrasing from Michelin's response.
Tyres that are not used often, ie when a car is off the road, are adversely affected by two things; UV light and oils in the rubber compound not moving.
So, if a tyre is sitting still for prolonged periods the oils in the rubber 'settle' and make the tyre stiff which causes cracking and degradation.
There is also a third factor, which is linked to the oils. This is a tyre sitting on a cold, hard surface in one place for prolonged periods. This causes the oils to harden more at the point of contact with the ground.
Pumping the pressures up to higher than optimal operating is of no benefit, apparently, and can cause more damage due to the oil issue above.
Their advice was to keep tyres indoors (say a garage), keep them as warm as is possible, move the tyres as much as possible and insulate them from cold surfaces.
I keep my car(s) in a garage all winter with the tyres sitting on four pieces of old carpet to insulate them a bit from the cold concrete. I jack the car up every few weeks and rotate the tyres by 90 degrees or so each time. It is a faff but tyres are expensive, so who wants to throw them away if they can easily avoid it?
ChrisD
Evesham
M44
This is what the Z3 owners handbook states on the topic:
I have mostly followed this when putting my vehicle in storage for 12+ months. I had no noticeable issues with keeping the tyres at high pressure when off the road for a number of years.
These days, for off road storage during winter I throw an old set of wheels/tyres on and keep my nice new summer tyres fresh and fragrant in a warm, dry, dark storage unit.
