Afternoon all.
At some point over the winter my blower motor has stopped working (on all settings). Between it working and not, the car just sat for a few weeks with the battery disconnected - Meaning to say that I wasn't poking around or changing anything.
I have checked the fuses and I swapped the relay with another of the same colour (presumed to work - since there are no other functions of the car inop). I think I am right in saying it is not the resistor, otherwise it would still work on the highest setting because the resistor is bypassed, right?
Before I buy a replacement motor, my plan is to open up the scuttle to access the motor and then use a multimeter to check that power is actually being delivered to it. This should tell me whether the problem is the motor itself or the power/signal. Does that sound a sensible plan of attack, or am I overlooking a flaw in my logic?
If it's relevant the AC & Recirc buttons still illuminate and I can hear stuff happening when I cycle them.
(In similar threads Tony suggested using a power probe to supply 12v directly to the motor - but I don't have a power probe. In another thread somebody else had forgotten to plug the HVAC control panel in - but I haven't had mine out since before it stopped working, so I don't think it can be that!).
Thanks in advance
Thanks in advance
