Hi folks
I'm sure I'd get there in the end, but I'm also sure I can speed the process with your input!
Drove it into my garage, to do a quick re-bush, 4 years ago, and it's now ready to leave, except she won't start!
Battery was disconnected.
Dash lights as normal, cranks over. No spark and no fuel.
Fuel pump runs if I bypass the relay.
OBD system I'm using is Delphi, which has always been excellent connected via 20 pin connector under the bonnet, and is showing no fault codes. ECU has been reset. OBD1, no 16 pin under the dash.
Car is pre-face lift 2.8 with M52B28 single Vanos engine.
Build date May 1998
Spec list does not include factory fitted alarm, so it must have been fitted by the dealer.
Keys are the older non-remote version.
I don't have a brick type remote, the alarm has never been used, but has never caused an issue. Always just locked it on the key.
Should I be looking at an alarm/immobiliser issue caused by the long disconnect period, or does it point towards engine issue?
Thoughts really appreciated, pressures of life means time to work on it is limited.
Build date May 1998
