So I took the 2.2 out for a drive a few days ago and it ran flawlessly. Went to start it this evening and it fired up for a split second then cut out. Tried again same thing. Third time lucky I thought, so pressed the accelerator and it came to life, perfect I thought, time to go for a drive... nope. I have no acceleration whatsoever regardless of how far I press the pedal. I checked the pedal bushes and they're all fine, spring etc still in place. It also idles fine.
As it's fly by wire will this be the throttle position sensor? Or is there another sensor on the pedal side of the circuit that may have gone? Thanks
