Long time BMW owner/BMWCCA member, picking up a '97 2.8 Z3 this week
e30cabrio
Waiting for bolts to mount the Sequoia motor on it's stand so I can have room to assemble the rest of the BMW motor.
e30cabrio
Got the Sequoia motor properly on the stand today, the rotating deal is super easy to use.
Starting to get the garage organized for the S52 install.
[IMG]
[IMG]
[IMG]
[IMG]
e30cabrio
Exhaust is done, still have the radiator, oil cooler, power steering plumbing & placement of it's reservoir & to smoke test the intake/sc piping. The clutch return spring needs to be put together & while it sounds like nothing, it's a PITA of the most extreme proportions, I cannot express how much I wish I had left the clutch master/pedal alone!.
e30cabrio
Fuel pumps hate me, I tried to start the car had to pull the pump back out, it didn't like the plastic hose, I have a 50.00 submersible hose for the Sequoia I'll put in.
[IMG]
[IMG]
[IMG]
It's aliveeeee!!!!
Still needs it's cooling system, belt, power steering reservoir & plumbing & to bleed the clutch slave
View: https://vimeo.com/1064078656?share=copyI
I accidentally got the clutch master. Trying to put the pedal back together, the spring was impossible, looking for a write up I found one saying to delete it.
https://www.bimmerforums.com/forum/showthread.php?1956868-New-mod-clutch-spring-delete
Everything from 8-13. tried it with no spring & it seems to work but feels very loose.
Maybe because the slave needs te be bled?
e30cabrio
Upper & lower hoses, expansion tank & it's mount, powersteering hoses & fluid & bleed the clutch are all that is left.
Put the radiator in, of course the widest part where the wire is landed near the water pump.
Pushed the shroud in & rotated the fan.
