Door removal
Sp02zbr
guys and girls.
Is there a guide to removal of a complete drivers door.
Need to take one off.
Cheers.
windym
Hi, its easy just undo the hinge bolts at the bottom, and unplug the electrics from the pillar. The electrics are held on with two 8 or 10mm nuts, pull the rubber sheath off and you will see the plug.
On the top of the plug is a release, gently pry it forward and up and the two halves will disengage. Then just lift the door off its pins and thats it.
Andy
Sean d
Lincolnshire
Make sure you remove the check strap, its a pin that knocks out from the bottom up
